idle steady climbing
Old Oct 8, 2012 | 10:04 AM
fivepointohno's Avatar
Default idle steady climbing
truck was running great didnt start it for about 2 weeks came back and truck would not start found that the selonoid was stuck in the down postion moved it by hand and it started and then worked on its own but the idle is just steading climbing when it starts. so not sure what could be the problem. I only let it get to about 1500rpm before I shut it off.
stats on the truck is- 4k, 18* timing, air dog, hamilton cam, s480 under a hx35, 5x14 cpp injectors
update- checked for a stuck rack and that turned out to be working fine it was warm a few weeks ago when i started it 85 degrees today it is cold 61 outside. think it could be somthing to do with that
so it seems some how the cruise control linkage got caught up with the accelerator linkage. un hook all linkage and runs like a champ again!
Last edited by fivepointohno; Oct 8, 2012 at 10:04 AM. Reason: Automerged Doublepost
Old Oct 8, 2012 | 12:09 PM
dfiperformance's Avatar
FormerVendor
How tight are the 4Ks?
JoeyMiR
9
Feb 3, 2018 10:05 PM
MechanicalDiesel
Aug 11, 2015 08:14 PM
jordanokc
Feb 8, 2015 03:59 PM
cdetterer
15
Dec 8, 2014 08:46 PM
JMC23
5.9L 24V Performance
Oct 28, 2014 11:03 PM
