He351ve turbo on idi
Old Oct 7, 2012 | 11:06 AM
91dirtydiesel's Avatar
Default He351ve turbo on idi
Not driving yet, still need to finish exhaust, get intake boots still and get stiffer spring for the lever
Old Oct 7, 2012 | 04:08 PM
McFadin1stgencummins's Avatar
I like it, have you got to drive it yet if so how does it drive?
Old Oct 7, 2012 | 10:43 PM
Boosts fast, boosts high. Great upgrade
To scared to go much over 15
Last edited by 91dirtydiesel; Oct 7, 2012 at 10:43 PM. Reason: Automerged Doublepost
Old Oct 17, 2012 | 08:24 PM
blacksmokeaintbroke's Avatar
BADASS
Old Oct 17, 2012 | 09:20 PM
Thanks, took it on freeway and could cruise up hills at 2100 rpm at 65ish at 700-750 egt with 17-20 psi just cruising
Old Jun 22, 2013 | 10:56 PM
daves93f250's Avatar
Are you using studs or just stock.
Old Jun 24, 2013 | 01:55 PM
Stock, 230,000mi. It sees 20-25 pretty regularly now, holds up fine
Old Jun 27, 2013 | 11:27 PM
4x4manonbroke's Avatar
It won't last ..... its not weather it can or can't ...... its a game of how long will it do it for ...mmm that's the big unknown
Old Jul 8, 2013 | 11:20 AM
Why is it you think that?
Old Jul 8, 2013 | 09:59 PM
I'm pulling my IDI apart ... will post you pictures of the head ... and it will explain its self... or go to youtube and look up
after you watch this ... u will have a better understanding of what I mean ..... the combustion chamber is in the head and not the piston so by "boosting" these engines you will be more prone to issues like the inserts coming out and or heating up and coming loose and beating up you cyl. head and the block .... not to mention the stress on the head bolts .... and no studs are not a fix... these engines are just not real boost able .... I mean they are .. just not for as long as one with out a turbo ... and the power is not there to support all the money it will cost you to do this build right....
