To swap engines or not to that is the question?
Old Oct 6, 2012 | 02:22 AM
36Valved I6s's Avatar
Default To swap engines or not to that is the question?
To swap engines or not to that is the question?-oh-fuck.jpg ok so pic shows the area of the back of the block an flex plate there is a crack that goes down behind it but not above it.....advice should I use this engine its a VE Pumped 93 12 Valve with about 250k miles it ran fine when I began the tear down an tonight while looking at area to run my fuel line an misc parts I noticed that Crack......So use this or go to a later say 96ish P Pump engine an get a 47rh along with it?
Old Oct 6, 2012 | 07:54 AM
1stgenblowingsmoke's Avatar
The rear main seal is in a big aluminum housing behind the flex plate. that's what is cracked. but honestly man swapping engines would be easier then swapping all the hardware.
Old Oct 6, 2012 | 08:02 AM
bladeyamaha's Avatar
Yeah, just get a flexplate dude.
Old Oct 6, 2012 | 08:30 AM
I thoughtso at first too but if you look closely the flex plate has triangle shaped holes in it n the crack is in one of them holes.
Old Oct 6, 2012 | 08:34 AM
Oh wow! You are so right! Bummer!
Old Oct 6, 2012 | 08:39 AM
i was thinkin that was aluminum was a late night full of a bad mood for me wasnt thinkin much...so how much of a pain in the **** is that to do the rear main seal plate?
Least there is hope for the VE Pumped dream
ReckONE
Diesel Engine Conversions
Feb 25, 2015 09:41 AM
Feb 23, 2015 06:20 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
Jgloveracob
Nov 16, 2014 07:27 AM
Duncan
Oct 28, 2014 12:34 PM
