what mark do you set index on ve pump?
Old Oct 5, 2012 | 11:41 AM
willyslick's Avatar
Default what mark do you set index on ve pump?
changed govener spring to 3200 now wont run right.start and goes to high rpm
have fuel screw as low as it will go and run
i have tried different index marks
help
Old Oct 6, 2012 | 10:57 AM
lodal cummins's Avatar
I believe it is the second notch you want lined up with the grove ontop of the shaft
Old Oct 7, 2012 | 07:44 AM
willyslick's Avatar
took this pump apart 3 times this govener spring mods killing me.i had it idleing nice at one one point but when i move the throttle set amount it just keeps accelerateing.tried backing off the fuel screw till it wouldnt start.
Old Oct 7, 2012 | 09:35 AM
When you put the pump cover back on do you have the power screw backed all the way out where you see the o rig on the shaft? Yes the second notch is what you want
Old Oct 7, 2012 | 10:34 AM
willyslick's Avatar
i backed it out to where it wouldnt interfear with lid install. yes im on second notch.
now wont start acts like fuel solinoid again.
Old Oct 7, 2012 | 01:53 PM
Sounds like your doing everything correct to me. So I found a vid for you rather than explaining it in type. Go to YouTube and type in BD gov. Spring very good vid that will show you step by step. Just to make sure your fuel pin is correct and to see if fuel pin not hanging up
Old Oct 9, 2012 | 09:46 AM
willyslick's Avatar
watched video, when throttle lever moved little pin does not come out in fuel pin bore?whats up?
Old Oct 15, 2012 | 10:01 AM
78fordf150ranger's Avatar
Mine was doing the same thing, I poured some new ATF fluid on the pin with top off and cycled it a couple of times to get the stickieness out. But I to still cannot get my to run after the gov spring install. I get a ton of white smoke and it just kicks but won't run...
Old Oct 16, 2012 | 10:49 PM
willyslick's Avatar
ok,got her on the second notch,played with fuel screw turned down ,got her stable.
drove around for and hour not going over 30 and no more than 1500 rpm.
seems to me the govener acts different with the stiffer spring. unstable in park at lower rpms it hunts around.at higher rpms around 2000 becomes stable and holds.
going to adjust smoke screw this week to richen it up a bit.
maybe the bigger injectors and turbo comes in to play also with fuel screw not being turned in as much as before i did mods. going to test on highway and push it later this week.
thanks lodal for your help.that video was great.
hey 78 ford maybe that white smoke is that tranny fluid you pored down on that pin.
make sure that index is one the second and 4 position and turn in the fuel screw 1/4 at a time and try to start.after each adjustment before you start make sure to snap throttle full open to set adjustment.of course befor you do this crack your bleed screw and pump you lift pump by hand until fuel comes out the bleed screw.make sure you leave the pump handle in full up position before you try to start.let me know how this works.
Last edited by willyslick; Oct 16, 2012 at 10:49 PM. Reason: Automerged Doublepost
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
HardLuck
Jun 24, 2015 08:04 AM
ctjkelley
Jun 3, 2015 06:01 AM
Gm3500
May 7, 2015 11:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
