black sludge in radiator
Old Oct 3, 2012 | 02:31 PM
98ram's Avatar
Default black sludge in radiator
My truck only.has 140,000 miles on it and this morning when I drove it everything was fine. But about an hour later it was starting to over heat so i parked it and just now had time to look at it and there is a thick black sludge all over the radiator. I checked my oil it was a little low and it was thick as well. I have never herd of this happening before so I'm lost on this one and need it fixed fast.
Old Oct 3, 2012 | 04:27 PM
cumminstothefloor's Avatar
Check under the oil fill cap for any mud-colored build up, white colored exhaust, hard radiator hose, turn your heat on and if it smells sweet it could be coolant. Sounds possibly like a bad head gasket.
Old Oct 3, 2012 | 09:42 PM
tiremann9669's Avatar
In the rad or all over the outside ?
Old Oct 3, 2012 | 10:18 PM
lunk's Avatar
if you mix the red coolant with the green coolant it turns to sludge and clogs the radiator
Old Oct 4, 2012 | 04:06 AM
angelic0-'s Avatar
blue, red, orange, green.... none of them mix... you should always add the same colour coolant...
Old Oct 4, 2012 | 06:27 PM
hounddogks76's Avatar
If your oil level is low also, i would bet on a head gasket or if you get lucky, maybe the oil cooler gaskets.
drain some in a clear jug and let it sit for a couple hours. If it seperates and you have green antifreeze on bottom and bleack oil on top, then that would rule out mixing different antifreezes.
Last edited by hounddogks76; Oct 4, 2012 at 06:27 PM. Reason: Automerged Doublepost
Mar 13, 2015 09:20 AM
Dec 5, 2014 05:50 PM
UC Kid
Oct 20, 2014 10:06 AM
