Chevy/GMC Duramax 04.5-05 LLY Discussion of Chevy and GMC Trucks with LLY Duramax Turbo Diesel Engines
EGR Leaking Oil
Old Mar 9, 2008 | 02:26 PM
MadMooseEngineering's Avatar
Default EGR Leaking Oil
So my 05 silverado is leaking oil out of my egr. My egr has been blocked off and turned off using EFI Live and I even re routed my pcv valves to dump in the air. So i was wondering if anyone has had this issue or knows of a fix because it concerns me.
Old Mar 9, 2008 | 02:29 PM
DangerousDuramax's Avatar
This is the residual that is purging out of the system. You would be surprised if you knew how much built up just after 5K
Old Mar 9, 2008 | 02:31 PM
ahh okay so its not a big problem then
Old Mar 9, 2008 | 02:32 PM
Tear the intake and EGR system down and clean it really good. If you have the time take your CAC off and have a radiator shop flush it out.
Old Mar 9, 2008 | 02:35 PM
okay i think i will go tackle that problem today far as the intake and egr the other thing might have to wait a bit.
Old Mar 9, 2008 | 02:37 PM
When you are able to get the CAC cleaned, run a thin bead of silicone on the inside of your boots when you put them back on.
Old Mar 9, 2008 | 02:41 PM
okay i will do that
Old Apr 9, 2008 | 10:48 AM
LarryJewell's Avatar
PPE makes a nice EGR Delete kit, or if you tear it down I bet you can see how to really block it for good with a little welding and a blocker plate.
Old Apr 18, 2008 | 09:29 PM
Thanx Im currently building a new intake piece to completly remove the egrs on these trucks kinda a off road only piece but thats noit going to stop me running around the streets with it
Old Apr 18, 2008 | 09:40 PM
got any pics or more details
