new s400 turbo boost issues
Old Sep 29, 2012 | 10:12 PM
jbenbow2's Avatar
Default new s400 turbo boost issues
Have a 1997 12v ext cab long bed 4wd manual, truck has fuel plate removed manual fuel shutoff valair600 horse single disk, cold air intake, arp studs timing advanced 15 degrees, 300 horse injectors, 5 inch turbo back, steed speed exhaust manifold and a brand new s400 turbo with a billet 6 blade compressor upgrade built by tdi. I just got everything hooked up on the new turbo and I'm only getting 10 psi in second gear, 25 in third 35 in fourth and 50 psi in 5th gear, I'm not sure what my issue is, there is no boost leak anywhere in the piping. The turbo run as a single according to the builder with the fuel delivery my truck has should push at least 60-90 psi. It doesn't lite up untill 2000 rpm but I cannot figure out why it is not boosting substantially higher than 50 in all gears. I've always been a 24 valve guy where if it smokes you can tweak more boost to match fuel, this thing smokes like a holy nightmare but Im not sure how to figure out what my issue is with the 12v. It also ha 3:55 gears and a dana 80 rear. any help would be appreciated.
Old Sep 30, 2012 | 02:20 AM
Djc25541's Avatar
Do you have a GSK?
Old Sep 30, 2012 | 02:32 AM
jbenbow2's Avatar
I have beehive valve springs billet pushrods and 4500 rpm springs in my garage..just concerned i need to go through the bottom end and balance it before i install the gov springs..new to 12 valves idk what i can get away with without a full race build in the 12 valve
Old Sep 30, 2012 | 02:45 AM
Djc25541's Avatar
Really the only thing to worry about with GSK is valve springs. Other than that you should be ok
Old Sep 30, 2012 | 02:51 AM
jbenbow2's Avatar
Ill do the install on everything and see what she does. Thanks man
bramic1
Oct 1, 2015 05:10 AM
Da Bomb
Sep 3, 2015 10:00 AM
tjcarr05
Apr 29, 2015 06:41 AM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
