Truck won't shut off
Old Sep 27, 2012 | 10:10 PM
Bryce's Avatar
Default Truck won't shut off
This has happened to me twice now. Turn the truck off take the key out and it keeps on running. First time I thought my Edge module might have a turbo timer that I turned on without knowing it but 10min later still running. Had to pull the fuel relay to kill it. Second time, I decided to take it for a drive after turning the key off and on a couple times and I noticed when it shifted to 2nd boost was limited to 10psi, 3rd and 4th to 8psi and it acted like it was running out of fuel but I still had 14psi of fuel pressure. When I got back, still wouldn't shut off. After pulling the relay, I started it up and drove it and everything was normal. Any ideas on what caused this? Fuel shutoff solenoid? Thanks in advance.
Old Sep 28, 2012 | 10:07 PM
01quadcab's Avatar
remove your edge completely and see if this cures it. sounds like a programmer issue to me.
Old Mar 9, 2014 | 09:18 AM
cumminsturbo24v's Avatar
Do u have the edge juice w/attitude cts? If so u may have a turbo timer cause my truck just did that to me as well after I hooked up the constant wire in the engine bay fuse box. I turned the turbo timer off in the settings and my truck turned off.
doublehbar
13
Aug 9, 2015 12:35 AM
clarthom
8
Mar 5, 2015 07:27 PM
mountainmover
Big Rigs & Semis
Mar 1, 2015 06:03 AM
Dec 3, 2014 09:40 AM
Oct 14, 2014 08:40 AM
