did my 5th gear nut let go?????
Old Sep 27, 2012 | 08:05 PM
iceman1404's Avatar
Default did my 5th gear nut let go?????
So driving my truck 60mph in 5th and hit the throttle just a little bit and all the sudden it seems as a grenade went off inside the tranny, havent pulled it apart yet but im pretty sure i can see some starter gear laying in the bottom of the housing and thats about it. clutch is rated for 600 horse and i know im not to that mark yet. Would a 5th gear nut cause all this?
Old Sep 27, 2012 | 08:23 PM
hydroshok's Avatar
When mine went in the 99 it just made a pop and would free rev in 5th. All the other gears worked fine. I wouldn't think 5th gear (rear of tranny)would have anything to do with the starter gear (front of tranny). Did you keep driving? Other gears work? If you stopped maybe it was something with the starter and your 5th gear is fine. Unless you are just seeing things or your clutch was defective.
Old Sep 27, 2012 | 08:38 PM
iceman1404's Avatar
When it went out it was loud as hell i was expecting the bell housing to have pieces missing from it and when it happened i turned the key right off and shut it down right away, i had a friend with a trailer come get it. from the very small piece i could manage to get out of the housing looks to be something of cast metal. i know hard to say what happened untill its apart but i was not sure if a 5th gear not could cause such a catastrophe
Old Sep 27, 2012 | 11:46 PM
blacksally's Avatar
i wounder if your fly wheel blew apart??? yea i heard alot of 5th gear nuts coming off and it just looses 5th, ive seen a guy use a kit and do the 5th gear nut in about an hour!!! crazy
Old Sep 28, 2012 | 11:33 AM
RollinCoal99's Avatar
5th gear nut fix is $30 its worth it
Old Sep 28, 2012 | 04:55 PM
iceman1404's Avatar
Yea after talking to a few people it might be the flywheel or the clutch and not the 5th gear nut. I talked to a tranny specialist and he said the 5th gear nut coming of wouldnt cause an explosion, cause thats how it sounded.His bet was the shaft bearing or the clutch. The clutch in it is rated for 600 horse but i cant imagine im to that point yet. Going to tear it apart this weekend and find out what went on in there
Old Sep 29, 2012 | 08:20 PM
hydroshok's Avatar
Post some pictures for us. I'd like to know what it was...
Old Sep 29, 2012 | 08:33 PM
Bigg Redd's Avatar
VrooooooooooooooooooooooooomBOOOOMcrunchclangclangclanggrindcrunch....awshit....:sca re2:
Old Sep 29, 2012 | 09:28 PM
iceman1404's Avatar
Well i got the tranny out of the truck but havent took the insides apart yet but from what i can see now is the main shaft snapped, broke the race thats part of the bell housing i guess you would call it and thats it so far. Not sure what has caused it yet though. Lots of torque? Wish I had run the truck on a dyno before this
and yea i will try to get some pictures. Id like to put a picture of my truck on here to but i dont know how to do it haha. Ive tried to figure it out but i cant
Last edited by iceman1404; Sep 29, 2012 at 09:28 PM. Reason: Automerged Doublepost
Old Sep 30, 2012 | 10:54 AM
Bigg Redd's Avatar
Man, that sounds like an expensive repair.
corksil
Aug 2, 2015 10:19 PM
Jun 4, 2015 09:30 PM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:27 AM
rtbcoop
Nov 29, 2014 11:33 PM
miked2805
Oct 29, 2014 06:20 PM
