What would it take to hit 600hp?
Old Sep 25, 2012 | 08:34 PM
cheer's Avatar
Default What would it take to hit 600hp?
What would i need to do to hit the 600hp make with my truck? Ive got 100hp injectors ,phat shaft 64,hot rod injection pump, fass platnuim 150, trannys all done too...im forgetting something not sure what.... Could anyone help me out ??
Old Sep 25, 2012 | 09:48 PM
H.R.D's Avatar
I would dyno your rig to see where you stand now.
Remove the lift and big wheels/tires and you will be close. I recommend some headstuds and larger injectors.
You need to fill out your signature so we can see what you have with out you listing it every time. Just a tip
Old Sep 25, 2012 | 10:26 PM
holset cummins's Avatar
bigger injectors will help a lot like 150 or 175. after some head studs, i would also do some water injection and a small shot of nitrous like a 75 shot or a 100 shot. what would get you over 600 real easy.
Old Sep 25, 2012 | 10:34 PM
H.R.D's Avatar
Here is a buddies truck and also a DB member who goes by Scott@Alligator. If you read the video description it will tell you what he has done performance wise.
Old Sep 26, 2012 | 09:35 AM
crazycooter's Avatar
JUST MONEY
Old Sep 26, 2012 | 10:32 AM
Farmboy 2.0's Avatar
Originally Posted by crazycooter
JUST MONEY
Your right on that one! Big power is a vp truck is expensive but its very doable!
Old Sep 26, 2012 | 10:43 AM
mysterync's Avatar
Something like a 66 or twins, 220-300 horse sticks, drag comp and head work.
Sent from my DROID BIONIC using Tapatalk 2
Old Sep 26, 2012 | 10:51 AM
You dont need a 66. You can do it with a 64 and good tuning and good air flow mods. And you will have better streetablilty than with a 66 as well
Old Sep 26, 2012 | 11:09 AM
mysterync's Avatar
Never tried a smaller charger, I agree a 66 and street manners don't belong in the same sentence. If your going with a 64, make sure you look at a 71 or larger turbine.
Old Sep 26, 2012 | 11:19 AM
Yeah i run a silver 64 with a billet wheel. And I am hoping to break 700 on saturday with the new tuning and cam, intercooler, and what not
