Rear main seal
Old Sep 25, 2012 | 04:33 PM
Cow tipper's Avatar
Default Rear main seal
Okay so this weekend I am pulling out my motor to replace the rear main seal. I am wanting to paint the engine so what kind of paint should I use? Also while I have it out what other things should I replace? How much will this all cost?
Old Sep 25, 2012 | 05:59 PM
96blackcloud's Avatar
you dont have to pull the motor to replace the rear main just drop the trans and tcase if 4x4. when i did mine the seal was a neoprene kind and ran 40.00 dollars at napa. as for the paint look for cummins engine enamal if your looking for a factory cummins look.
Old Sep 25, 2012 | 10:01 PM
Cow tipper's Avatar
Trust me pulling the engine takes a lot less time.
Old Sep 26, 2012 | 10:50 PM
jwirth's Avatar
If you can pull that engine out in less then 30 mins you need to work on the automotive or large truck field. Should be able to pull trans with or without 4x4 in less then one hour for any good tech.
Old Oct 1, 2012 | 07:20 AM
Cow tipper's Avatar
Dude I'm 17 I'm still learning stuff. I want to paint my engine anyways
shingi
Off Roading
Sep 30, 2015 11:17 AM
yfzrunner
Sep 17, 2015 05:23 AM
Machinist
Jun 23, 2015 06:57 AM
Max713
Apr 17, 2015 01:20 AM
wildbill
Jan 31, 2015 11:14 AM
