I need a 94-98 timing cover case for p-pump 12v
True. But the reason why mine cracked was bc some pin broke and got slammed into the side of the case on the inside and I'm not sure if that pin is a part of the case or not? Or if I even need it?
LoL. yea I know. Thats called the KDP. Killer Dowell Pin. It got that name from exactly what it did to you. Its just an alignment pin for fitting the case on to the block. Find the pin... put it back in. Then bolt a tab that covers it to prevent it from falling out.
Weld that case back up.
U just need to make sure there's clearance for the gears and the back of the case is flat or else it'll leak. U can try it but it'll be a lot more work and money if it doesn't work right cause ull have to dear down your motor again new seals and put a new case on it
