Fuel Pressure Gauge Question
Old Sep 24, 2012 | 07:30 PM
zach2's Avatar
Default Fuel Pressure Gauge Question
I FINALLY installed an Isspro EV mechanical fuel pressure gauge and Big Line Kit. I got all of the air out of the isolator to gauge line. With only two years time on my Raptor lift pump, I show to only have 11psi at idle. WOT pressure drops to 8. Question is, do I have an incorrect reading at the gauge, or do I turn the pump pressure up? Any suggestions will be appreciated.
Old Sep 28, 2012 | 04:17 PM
Crackshot's Avatar
You have a VP 44 pump?
That's seems a little low to me.
Old Sep 28, 2012 | 05:24 PM
olaus's Avatar
factory calls for a minimun of 7 so you're probably ok, but I'd try to turn it up a bit so you're 10 wot and 14idle
Old Sep 30, 2012 | 05:11 PM
zach2's Avatar
Thank you! I will try that. Suppose I can trust my new gauge?
Old Oct 2, 2012 | 12:19 PM
01quadcab's Avatar
if it was a glowshift gauge I would say no. but a little more pressure will not hurt anything just keep it at 20 or below
Old Oct 18, 2012 | 07:36 PM
zach2's Avatar
Default fuel pressure gauge
Thanks! I have since turned the pressure up to 14 at idle. WOT pulls it down to 9psi. I read somewhere to beware of any drop of greater than 4psi. Is that a true statement and what else do I do about it anyway?
Old Oct 18, 2012 | 08:55 PM
Dodgemanstan's Avatar
I would like to see 12 psi to 16 WOT I think psi is too low... But to each his own.
Old Oct 19, 2012 | 05:56 AM
thesmellycowboy's Avatar
I have been having an issue with my overflow valve on my VP and my pressure is a little different everytime I drive. When the pressure is around 16-17 WOT the responsiveness seems to be a lot better than when it is 10-11 WOT. maybe its in my head tho
Phase to ground
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
scottxmorris
Oct 8, 2014 02:14 PM
