small issue. hoping isnt a big deal
Old Sep 24, 2012 | 05:59 PM
1st Diesel's Avatar
Default small issue. hoping isnt a big deal
Im having an extended cranking time and not sute why. Normally takes 2 seconds to start amd is now taking about 6-10. No mods. Just 5" exhaust. Done 3 injectors, 2 batteries, hpop, icp, ipr in last 7 months. Its an 03 with 137,000. Please help.
Old Sep 25, 2012 | 09:50 AM
Mdub707's Avatar
Checked the FICM at all? How does it run once it's fired?
Old Sep 25, 2012 | 11:29 AM
1st Diesel's Avatar
haven't checked the FICM yet. haven't had an extra set of hands with me. but will do that today. once its fire it pugs and chugs when cold but runs completely fine when warmed up. I noticed last night it is having a misfire. So i know one or two injectors are bad now. But one thing I forgot to mention is that last week is when it started running like crap and my assumption is because my water in fuel light was on. I'm pretty sure i got a bad batch of diesel from speedway cause the light was on until I managed to run the tank out of it. Since refueling it hasn't came back on.
Old Sep 25, 2012 | 02:09 PM
Mdub707's Avatar
Did you drain the water separator? How old are the fuel filters?
I'd double check the batteries and check that FICM before doing anything else, too easy not to do it.
Old Sep 25, 2012 | 03:48 PM
1st Diesel's Avatar
definitely plan on it. I did drain the water separator. fuel filters are about a month and a half old. I changed them before i brought the truck from new mexico to ohio about 4 weeks ago. i'll check the FICM and batteries and repost as soon as I do to let you know the voltage.
Old Sep 27, 2012 | 11:34 AM
1st Diesel's Avatar
Update: so i figured her problem out. FICM voltage is low. Koeo is 47, cranking is 40 and running is about 37-38. My brother in law is a computer wiz and should he able to solder it for me to get the voltage back to normal. Im pretty nervous. But would this ficm problem account for misfires, and a almost no hot start? She fires fine when cold. But when warm, i have to crank the s#!$ out of her.
Old Sep 27, 2012 | 12:39 PM
Mdub707's Avatar
Sure could yup. Try it and let us know how it goes!
Old Sep 27, 2012 | 01:26 PM
1st Diesel's Avatar
how in the crap do you pull the housing apart on the FICM? It is driving me crazy. I took all the bolts out that run along the edge of it. Do you just have to pry like crazy or is there some special trick that i'm missing.
Old Sep 27, 2012 | 01:34 PM
Mdub707's Avatar
Pull the inspection cover off and take those 7 screws out, they're holding it together too. Even then, it's tough sometimes. I usually run a utility knife through the two halves to separate the seal made there, then pry it.
Old Sep 27, 2012 | 01:38 PM
1st Diesel's Avatar
AHHHHH. Ok. Thank ya MDub. didn't realize I had to take the 7 screws out also. Thankfully I didn't keep prying. Hopefully my dumb@$$ didn't break anything.
