fuel filter
Old Sep 23, 2012 | 07:59 PM
bulldog99's Avatar
Default fuel filter
I was replacing my fuel filter today took 6m drain plug out fuel did not stop coming out seemed like about half gallon.I put the drain plug back because it did not stop.It seemed like way to much.Is there a issue?:
Old Sep 24, 2012 | 07:32 AM
Mdub707's Avatar
Might have just got a bad batch of fuel some where with a lot of water in it... I usually get a fair amount of of there. 1/2 gallon sounds about right. I doubt there's an issue, I'd let it drain honestly. What fuel filters are you using? Hopefully Ford/International...
Old Sep 24, 2012 | 03:17 PM
bobfbigman's Avatar
Did you change the upper filter first? if not it will act like a siphon and keep dumping fuel out the drain
Old Sep 25, 2012 | 09:46 AM
Mdub707's Avatar
I always do my bottom one first, never even gave that a thought.
Old Sep 26, 2012 | 05:00 AM
bulldog99's Avatar
Default fuel filter
I let it drain finally stopped,just seemed like more than normal.Thanks for the help! As for what filters I use .I use Amsoil on everything .
Old Sep 26, 2012 | 07:49 AM
Mdub707's Avatar
I've used Amsoil oil filters in the past, they seem good. For fuel filters... I'd still stick with Motorcraft/International personally, but I haven't heard ANYTHING about Amsoil fuel filters. Some of the aftermarket fuel filters don't have the water membrane on them to fully separate the water properly.
Dbleo351
Nov 20, 2016 09:34 AM
jeffersonl
Nov 15, 2015 07:35 PM
moneypitk5
Feb 12, 2015 11:01 AM
jeffersonl
Oct 25, 2014 06:46 AM
james2562
Oct 8, 2014 06:14 PM
