Code p0275?
Old Sep 23, 2012 | 07:31 PM
2.S.F.L's Avatar
Default Code p0275?
My 06 F350 is throwing the p0275 code? I found out what it means When maximum/minimum pulse width adder is exceeded and cylinder does not converg a fault is set. I dont understand what that means? can someone fill me in on what causes it and what the fix is?
Old Sep 24, 2012 | 07:31 AM
Mdub707's Avatar
That's incorrect, not sure where you got that info from...
P0275 is cylinder 5 contribution balance/fault. Most likely injector number 5 needs replacing, but I'd run a contribution test on all injectors first.
How does the truck run now? How old are the batteries? Have they been load tested at all? I'd recommend that, and then test the FICM, you can find the test procedure at the top of the page. Both of those are easy and free to check, and it's smart to eliminate them as possibilities before replacing an injector.
Old Sep 24, 2012 | 06:54 PM
2.S.F.L's Avatar
when at wide open throttle it seems to almost have a miss and when I first start the truck in the morning it will puff alot of white smoke at a takeoff untill its been running for about a half hour or so. The smoke smells like raw diesel. Also my battery light will flicker on and off once and awile, i checked the batts with a meter and they read 13.7 volts. do you think any of these other problems could have something to do with this code?
Old Sep 25, 2012 | 09:58 AM
Mdub707's Avatar
Yeah basically everything but the battery light describes a bad injector. I'd probably replace that one if it was me.
dwmeehan
Sep 6, 2015 04:20 PM
Saams69
Jul 20, 2015 11:21 PM
flash7210
Jul 5, 2015 09:25 AM
robbyS
Apr 16, 2015 02:22 PM
Backhoeman
Jan 3, 2015 12:53 PM
