hx35/40 boost #?
Old Sep 23, 2012 | 06:11 PM
dieseldude848's Avatar
Default hx35/40 boost #?
built an hx35/40 hybrid turbo, and put a new wastegate on it, it wasnt adjusted, i adjusted it to where i think it should be, and its putting out a solid 31lbs on the guage is that too high, too low, or just right? i also have a boost controller on it.
Old Sep 23, 2012 | 06:40 PM
Smarty=Cummins's Avatar
If it was me i would up it to 38-40psi.
Old Sep 23, 2012 | 07:13 PM
c farmer's Avatar
Yea I am running 40 through a stock hx35. You caould go to 40. It doesnt look like you have studs so dont go over 40.
Old Sep 23, 2012 | 07:15 PM
RollinCoal99's Avatar
X2 40psi
Old Sep 23, 2012 | 08:03 PM
ok ill turn the gate up some more then. also ive read before theres a company that makes a better flowing comp wheel for an hx40? right now i have the stock 6 blade in there out of the 40.
Old Sep 24, 2012 | 03:04 PM
shellinger's Avatar
In level ten on my quad adr i have hit 41 psi with my stock hx-35, is that too much? i am a little nervous after reading this, i have only done a few times i usually leave it in level one.
Old Sep 24, 2012 | 06:42 PM
41 is fine but try to save up for head studs. With head studs n stock gasket im running 52psi n doing just fine.
Un4givn
10
Apr 27, 2015 01:58 AM
stewart.william.c
Feb 11, 2015 01:39 AM
ash23k
Dec 30, 2014 08:31 PM
Tsgbk9
Dec 23, 2014 11:54 AM
offroad00
24
Oct 23, 2014 03:28 PM
