Help vp44 issues
Old Sep 23, 2012 | 12:41 PM
Hotrod2702's Avatar
Default Help vp44 issues
Hey there I'm new to this site but I'm having some serious issues. The other night I went out to my truck an tried to start it and had to crank on it for about 40 seconds before it would sputter to life. After it started I drove it without any issues. The two days later it did the same thing so this time I bumped the starter and let it run for the 25 sec or so then it started just fine. I did notice a small puddle of fuel under the tank so I traced the issue to the in tank pump and figured it was sucking air into the line. That night I was driving and notice my rpms dropping at a stop light and it wanted to die. So I revved it up and made it into a parking lot where it stalled and would not start. I replaces the in tank fuel module and still couldn't get it to start and replaced the cps still nothing. Replaced the IP and and I still can't get the truck to run. It will run when you spray diesel starting fluid in it and I can tell I am getting fuel to the pump but not through it. I hot wires the pump and can hear the solenoid click in it but that's it. Is it possible that they sent me a bad replacement part or should I be looking at something else. Hope someone can help me I'm having to drive a car!!!
Old Sep 23, 2012 | 07:35 PM
blacksally's Avatar
starting fluid is bad!!!!!!!!! you replaced your injection pump, i had a problem were mine would die and it was the lift pump.
Old Sep 23, 2012 | 07:38 PM
RanchhandTCR's Avatar
check you fuel pressure from the lift pump to the injection pump and see if it will finally pull thru the injection pump, my buddies 01 died after the Lift pump died.. other than that check for codes and see if anything comes up..
Old Sep 23, 2012 | 09:50 PM
Hotrod2702's Avatar
It showed that I was getting 8psi for my fuel and I'm not showing any codes I'm truly at a loss
Old Sep 24, 2012 | 07:45 AM
blacksally's Avatar
mine did the same but i also had a code for low voltage at the lift pump once n while to, could ur truck have some bad fuel?
Old Sep 24, 2012 | 08:44 AM
Hotrod2702's Avatar
It's hard telling if I have bad fuel because I'm not getting it through the pump I have fuel all the up to it but none going into the injector lines.
dwmeehan
Jan 29, 2025 12:13 PM
justinsbeck
Jan 18, 2016 12:15 AM
octopusmotor
Mar 19, 2015 02:22 PM
somarillw
Dec 15, 2014 12:00 AM
Polaris04
Dec 1, 2014 08:27 AM
