Turbo rebuild
Old Sep 23, 2012 | 10:27 AM
nelson86m's Avatar
Default Turbo rebuild
Has anyone rebuild there hx35 turbo, how hard is it, and what all parts do i need? also seen the kits on ebay, has anyone used these are they any good?
Old Sep 23, 2012 | 10:49 AM
BarryB's Avatar
interested in this myself, I'm considering rebuilding mine also. I have a cousin in law that messes with turbo Mitsubishi's and buick grand nationals. He told me about this site for turbo parts. G-Pop Shop
Old Sep 23, 2012 | 11:29 AM
nelson86m's Avatar
Cool, i will check them out.
I also have another question, i checked my turbo for play side to side and back and forth, and have almost no play at all, how do you tell if it needs rebuilt? and the reason i was wondering about rebuilding it is because when boost is at 20psi or higher and let off the throttle i get a chattering sound from it, mostly does it when towing heavy loads.
Old Sep 23, 2012 | 11:59 AM
wyodiesel92's Avatar
Sounds like your describing turbo bark. Happens when at high boost levels when you let off the go peddle too fast and causes the turbo to surge.
Old Sep 23, 2012 | 08:33 PM
dodge rodder's Avatar
on the ebay turbo rebuild kit, i just did mine and i haven't had any problems with it,
Old Jan 20, 2013 | 01:13 PM
fahtb0y's Avatar
It's easy.
The hardest part is getting the exhaust housing off. Use some heat evenly around housing and stay away from center section with torch. The giant snap ring holding the compressor housing on is a pain to get back on. Look around here and other forums for instructions with pictures maybe even youtube
Old Jan 20, 2013 | 01:54 PM
shellinger's Avatar
a little side to side play is ok. when the turbo is on and oiled is flowing to it, most side to side play is diminished. if you can pull the shaft forward and push it back then its time to rebuild.
Old Jan 26, 2013 | 04:08 PM
countycoalroller's Avatar
i used to rebuild turbos professionally and the stock cummins turbos are very easy to rebuild. there isnt much to them but you will want a good set of snap ring pliers to take the old bearings out and to replace the new. also make sure not to over torque the turbine wheel and compressor wheel when you have it as a cart. if you do that you will burn up te bearings alot faster than you should. shouldnt take more than 3 hours total time since its your first one. i was building them in 20 min back when i did it everyday. and yes some side to side play is normal but front to back is death. good luck!
Old Jan 27, 2013 | 08:23 PM
CumminsCrazed's Avatar
hmmmm, mines got some play, but it looks like it may have contacted the housing one or two times....is that need to rebuild? also im getting a strong burnt oil smell out of exhaust at start up or when ui rev it, never at idle....is that bad seals in turbo leaking oil by?
avatardvr
18
Aug 8, 2019 12:38 AM
n2brk
Feb 21, 2015 09:05 AM
Whitereaper12v
Jan 28, 2015 11:01 AM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
