Shuttle shifting 47re
Old Sep 20, 2012 | 09:44 PM
Djc25541's Avatar
Default Shuttle shifting 47re
Shuttle shifting, what is it? And how can I fix it
Old Sep 23, 2012 | 08:41 PM
Djc25541's Avatar
OK let me elaborate. I bought this 96 12 valve. It's an automatic and I was told it has a moderately built transmission in it. It's suppose to have a Goerend VB and TC. Is their anyway to tell for sure? But my problem is that sometimes when it goes to shift it'll act like its slipping in between gears almost. It happens more frequently when I'm on a hill and it tries to shift into OD. Any input would be great. Just want to know where to start.
Old Sep 23, 2012 | 08:48 PM
RanchhandTCR's Avatar
There no way to tell if there realy in there without pulling it appart so Im assuming your truck is trying to shift and while its doing it it its slipping or is it slipping while in gear and it just jumps up the RPMS?
Old Sep 23, 2012 | 09:01 PM
Djc25541's Avatar
well that sucks that I'll have to tear into it to tell. and its starts to act like its slipping as soon as it trys to shift. the RPM's dont change though. if this makes since. sorta hard to explain
Old Sep 23, 2012 | 09:14 PM
hmm, hopefully rawwilliams shows up because hes the diesel wesel of cummins, but I would make sure you have good terminals on your batteries, and check you fluid, make sure your connection on the tranny are good and no freyed wires thats where I would start, because if your transmission was slipping then the rpms should jump...
Old Sep 23, 2012 | 09:20 PM
Djc25541's Avatar
thanks ill start with searching for freyed wires. could it be my VB pressure might need turned up? or anything like that?
Old Sep 23, 2012 | 09:48 PM
yea it could be, its kinda hard since I cant be there to see how its running, if its possible for you can you take a vid of it doing this? maybe that kind help explain a little more for everyone who can help ya.
Old Sep 23, 2012 | 10:12 PM
Djc25541's Avatar
yeah ill def try to get it on video. it would be a lot easier than trying to explain.
Old Oct 4, 2012 | 06:40 AM
woodsmen's Avatar
Supposedly with a georend torque convertor you can take the inspection plate of botttm of transmission three screws. With the engine off of course. Then take a pry bar or similiar and rotate the ring gear until you find the drain plug and there should be some numbers there, write them down, and call georend and they can probably tell you what you have. I am having sjifting problems with my 97 that i am going to post again later for help. I have talked to georend seem really helpful.
Old Oct 4, 2012 | 06:50 PM
gyayo2012's Avatar
http://www.xtremediesel.com/manuals/1030416.pdf
here is some info someone posted to me a while back, I was also having some shifting isues with my trans... try adjusting your tv cable and see how you make out.. from what i understand the cable controls your line pressure for 1-2-3 shifts.. hope it helps let us know!!.. there are also some screw on the v/b that control pressure setings but do the simple stuff first
rstrange1996
Aug 24, 2015 10:25 PM
dieselpowa
Jun 18, 2015 12:44 PM
metrickjb
Jan 21, 2015 04:16 AM
SixSpeed
Jan 11, 2015 01:41 AM
Alfdude1
Jan 9, 2015 01:19 AM
