Just a lil help plz
Old Sep 20, 2012 | 07:48 PM
CLM64's Avatar
Default Just a lil help plz
my mods are in my sig but my truck is lazy when i drive down the road and get in to it. it is like something is holding it back even with the mods my truck has been lazy but since i have got away from the sled pulling thing i want to use my set up and turn it to be a quick street truck so im asking for help on what to do
thanks Chris
Old Sep 20, 2012 | 08:39 PM
Red_Rattler's Avatar
High Tech Redneck
overfueled and choking it out... Rolling into it or flooring? Why so low on the timing?
Old Sep 20, 2012 | 08:42 PM
daveO's Avatar
How much boost are you seeing? Fuel pressure? You might want to look into a more streetable turbo/injector combo. I would imagine that 66/14 takes a while to spool.
Old Sep 21, 2012 | 07:08 AM
CLM64's Avatar
i roll in to it the turbo starts to come in around 1500 but don't light till 1700 i had the timing at 21 when i was pulling but seen no big gain in anything. And i run around 40psi of fuel to the pump and i can build 60psi on the turbo when it comes in but it builds to 30 pretty quick
Old Sep 23, 2012 | 03:49 PM
CLM64's Avatar
found a leak before the turbo and slid the fuel plate back close to stock and seams to of helped a bit its not as laggy as it was should i move the plate back father
Old Sep 23, 2012 | 07:30 PM
daveO's Avatar
You're probably in a good spot as far as the plate goes, maybe try adjusting the starwheel some and see how it feels.
Old Sep 24, 2012 | 03:35 PM
CLM64's Avatar
my star wheel when i set it i and start it it moves back to were is is lose its like there is nothing to keep it tight
itvinny
Jun 19, 2015 09:26 PM
itvinny
Jun 19, 2015 09:21 PM
