Oil coming out of dipstick?
Old Sep 20, 2012 | 12:20 PM
vexxxed's Avatar
Default Oil coming out of dipstick?
Hey guys. I've been looking around and found a few threads on oil coming out the top of the dipstick. But they are all talking about the oil constantly coming out. My notice it when I am running my truck at high RPMs like 2500 like on the highways. It won't do it if I'm putting around town.
There is air coming out of the breather tube below the motor, no oil comes out without the oil fill off, no vacuum leaks found yet, the o ring on the dipstick seems fine but will replace.
The truck is a 95 3500 4x4 auto 12 valve with 213k miles.
Thanks in advance!
1995 Dodge Ram 3500 Dually 4WD | 4" straight pipe to 9" Stack | Cold air intake | 18* Timing | Tuned AFC w/ stock Fuel Plate
Old Sep 20, 2012 | 08:19 PM
frenchcaper's Avatar
Default frenchcaper
Building up too much pressure. Need to relieve pressure. Sounds like rings. You can add a filter on top of valve cover. Drill tap pipe thread and thread in a small filter. Get you through till you rebuild. 5.9l can only create pressure through head gasket or rings
Old Sep 20, 2012 | 09:00 PM
BLACKSHEEP757's Avatar
he forgot 1 very important step in those instructions!******REMOVE VALVE COVER FIRST!!!!!!!!!!!******* METAL SHAVINGS IN ENGINE=NO GOOD!
Old Sep 20, 2012 | 10:30 PM
RanchhandTCR's Avatar
My question is also what is the oil level at on your truck? my two cents is I had a lift pump fail on a 4bt cummins and I had oil comming out and it was the fuel leaking out of the lift pump into the crankcase...
Old Sep 20, 2012 | 11:03 PM
Fox's Avatar
Fox
heres a trick to tell first... Just to make sure.
Unscrew your oil filler cap and just place it on top. Does it get blown off?
Old Sep 20, 2012 | 11:37 PM
vexxxed's Avatar
Cool thanks guys. I can vent it for now.
The oil was a little low. (Bottom of the mark)
I will try to just set the cap on top in the morning and get back to ya.
Old Sep 21, 2012 | 09:57 PM
Default frenchcaper
Sorry I assumed that the valve cover would be removed before being drilled but need to make myself clearer. Make sure you don't drive with that cap vented or you're gonna make a mess. The filter on top will keep your truck clean till you're ready to proceed with more work.
Old Sep 23, 2012 | 02:49 PM
vexxxed's Avatar
I'm just going to add a filter to one if the valve covers. Does it matter which valve cover or does one vent more than others?
Old Sep 23, 2012 | 06:17 PM
Default frenchcaper
It doesn't matter which cover, they all go back to reservoir. The only way to find out your exact problem would be to start with a compression test for each cylinder. If your engine is stock and depending on what horsepower your running you should be between 320 and 360lbs of pressure. If lower than that you could adjust your valves and make a second pass. If low compression you have ring or valve problems. Your engine smokin' any?
Old Sep 24, 2012 | 07:53 PM
captain_stabbin's Avatar
all that is normal, mine has 300k an does the same thing with breathers on valve covers,
lacrab
Sep 10, 2015 01:17 AM
|WYG|SS
Aug 19, 2015 10:53 AM
soco
Jul 27, 2015 06:06 PM
Jake12valve
May 10, 2015 11:57 PM
ramrunner01
Apr 25, 2015 10:11 PM
