Power steering line help!
Old Sep 20, 2012 | 11:09 AM
BuckeyeDMax's Avatar
Default Power steering line help!
While putting a pitman arm on my truck yesterday, I unbolted the steering box and must have moved it too far, I broke a PS line. One end of the line went to a metal nipple in the back of the PS pump, it was clamped on. Where does the other end go? The power steering box Im assuming? Is this a low pressure line? Does this line go through the hydroboost at all? Diagrams are much appreciated! Thanks!
Old Sep 20, 2012 | 11:26 AM
1AMatt's Avatar
Site Sponsor - 1aauto
Is the rubber molded with the metal, or is it clamped on?
Old Sep 20, 2012 | 11:27 AM
Clamped. There is a metal nipple that comes out of the pump. It appears to be pressed into the back of it. That is what the hose clamps to.
Old Sep 20, 2012 | 11:29 AM
1AMatt's Avatar
If its clamped together then its gonna be the return line. The pressure hose that goes from the pump to the box is all molded
Old Sep 20, 2012 | 11:31 AM
Does this hose go from the box to the pump? Or from the pump to the hydroboost? I only found one end of the broken line, I have no idea where the other is. Although im guessing its sticking out of the box. I cant quite find it.
Old Sep 20, 2012 | 11:36 AM
1AMatt's Avatar
Hmmm I am not 100% on that
Old Sep 20, 2012 | 04:52 PM
tiremann9669's Avatar
Might go to a cooler line that loops on the front of the crossmember
Old Sep 27, 2012 | 11:18 AM
1AMatt's Avatar
Any luck on this Buckeye?
Antwhite19
Aug 23, 2015 06:07 AM
ramrunner01
Jun 1, 2015 12:10 AM
krg3590
Mar 15, 2015 08:57 AM
1MooseheadPlease
Oct 13, 2014 05:33 AM
sweetv8s10
Oct 7, 2014 09:47 PM
