wait to start light
Old Sep 20, 2012 | 01:05 AM
alittle5150's Avatar
Default wait to start light
I noticed my wait to start light is not coming on before I start my 5.9 cummins... I have a 1999 dodge with a 24 valve cummins... I am new to all this and I would GREATLY APPRECIATE ALL THE INFO I CAN GET !!!! Thank you all so much !!!!
Sincerely , Richard
Old Sep 20, 2012 | 03:01 PM
RAW's Avatar
RAW
Does it come on when the dash does a bulb check? If not, it may just be a burnt bulb.
Old Sep 25, 2012 | 01:31 AM
thank you for the info i will check the bulb !!!! I hope that's all it is.... so far I believe I got a good deal it's only has 180k on the odometer... I installed am amsoil bmk22 oil filter system I can carry 4.5 gals. of oil now instead of the 3 gal. it used to carry... the oil is now being filtered down to 2 microns it has a full flow filter and 2 bypass filters that filter all the oil in my engine every 10 to 15 mins.
this is my first diesel .... and I'm trying to learn all I can !!!!! again thanx for the info
Old Oct 24, 2012 | 12:28 AM
i checked the bulbs they appear to work .. i switched them around and there was no diff it doesn't come on when do the bulb check.... I'm finally getting ready to check further... got any ideas ??? thanx
Old Oct 25, 2012 | 06:49 PM
RollinCoal99's Avatar
when you turn the key on you should be able to hear a high pitch ringing sound for 5 seconds which would be your grid heater working its below intake manifold
schwier94
Sep 26, 2016 09:07 AM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
bullrideris1
Jan 23, 2015 09:22 AM
NCC74656
Nov 4, 2014 10:46 AM
