04 F350 SD rough idle at times, loss of power with white smoke out exhaust
Old Sep 18, 2012 | 07:54 PM
sands0717's Avatar
Default 04 F350 SD rough idle at times, loss of power with white smoke out exhaust
its a 6.0 turbo diesel and it has a rough idle at times, loss of power with white smoke at times. it does not do it all the time as it only does it maybe once a day or not even at all... it comes and goes. i have changed fuel filters, pulled and cleaned the water/fuel separator.. no water in my oil, new air filter, pulled and cleaned the EGR vavle.. im just doing all of the small stuff to try and fix it, but it seems as though nothing is working... i sure could use some advice.. thanks
Old Sep 18, 2012 | 09:49 PM
Rick62268's Avatar
I am having the samw problem .And have trouble shot it down to my EGR Cooler.Is going bad. Also i am building presure in my cooling system.There is a white dry looking fuild on and around my Radiator cap.
Hope this helps.
Old Sep 19, 2012 | 08:34 AM
Mdub707's Avatar
Get your batteries load tested and test your FICM. The test procedure is at the top of the page in the 6.0 section. Very common issue with 6.0's.
Old Sep 19, 2012 | 01:33 PM
sands0717's Avatar
i just replaced my FICM no more than a year ago or so...
Old Sep 19, 2012 | 02:48 PM
Curry's Avatar
There is no schedule for ficm failures. Maybe uncommon to have a problem so soon after replacing. Better to scratch it off the list to be on the safe side.
Old Sep 19, 2012 | 03:25 PM
Mdub707's Avatar
It only takes a few minutes to check, and if you went with a new Ford unit, it will fail again eventually. Only real way to stop it is have it repaired, which is a fraction of the cost of a new one anyways.
Jet A Fuel
Aug 3, 2015 10:45 AM
Timglow546
8
Jun 3, 2015 10:13 PM
jordanokc
Feb 8, 2015 03:59 PM
zoomer10h
Ford Powerstroke 08-10 6.4L
Feb 6, 2015 01:38 AM
99stackedpowerstroke
Oct 8, 2014 07:06 PM
