Can i ask this here?
Old Sep 18, 2012 | 01:36 PM
cheer's Avatar
Default Can i ask this here?
Im woundering if i could make my 2500 ride as soft as a half ton i dont put loads in it and i got airbags in the rear..can i use a softer spring in the rear or something? Couldanyone help me out with this?
Old Sep 18, 2012 | 01:44 PM
biged681985's Avatar
Put half ton springs in the front, and get half ton leaf springs, should ride easier
B.E.D.S.
Big Ed's Diesel Service
Old Sep 18, 2012 | 02:06 PM
RAW's Avatar
RAW
I removed leafs from my rear, and the ride is way better. I also have air bags for when I tow.
I have heard, and correct me if this is wrong, that half ton springs won't work as they are narrower than the mounts.
What's with the attached picture? The reason you want it to ride smoother?
Old Sep 18, 2012 | 04:54 PM
H.R.D's Avatar
You will lose load carrying capacity with 1/2 ton springs.
Old Sep 18, 2012 | 06:01 PM
scottmorgan's Avatar
to run the 1/2 ton rear springs you would have to get a 1/2 ton rear shackle
larger tires with a d load side wall helps a ton as well! small rims large tires weak side wall equeals great ride wiht any truck
Old Sep 18, 2012 | 06:56 PM
BLACKSHEEP757's Avatar
sell your REAL TRUCK and go buy a dakota if you dont need a truck.....Hell,I'll go buy a Dakota and swap ya if you want!...I'll never understand why people buy a 1ton deisel truck (especially on 39"s) and then cry about it riding like a truck!
Attached Thumbnails Can i ask this here?-419851_273285302744207_1303189061_n-1-.jpg
Old Sep 18, 2012 | 07:06 PM
CR9712v's Avatar
No need for negativity man... people have and always will own trucks for their own reasons it's practical to have a heavy duty for working and towing but no where in the unwritten law of man does it say you have to.
Old Sep 18, 2012 | 07:48 PM
RanchhandTCR's Avatar
leave your coil springs alone in the front 1/2 springs wont hold up that engine. and different tires will help to, not load range C tires but D's maybe less ply to it if you dont tow that much... but any how its your truck so you can do what you please, plus the rams are a hell of a lot more comfortabe than a dakota I know because I had one
Old Sep 18, 2012 | 08:18 PM
easy guys......I was jokin......to each his own.......Hell,at least I didnt mention his tow mirrors being flipped up in the pic.....there I go being an again,sorry
Old Sep 18, 2012 | 08:19 PM
Yea uh
