W350 Custom wiring
Anyone do a complete new harness either from painless performance or anyone else out there with any info???
I have a 93 with a 46rh an want to bypass as much electrical an computure uses.....
Anyone that can help would be much appreciated!
Actually the computer doesn't do much on these diesels. Charging, A/C, Overdrive is about it. There are plenty of posts on here and other sites about bypassing it for these systems.
Try Dodge Diesel - Diesel Truck Resource - Cummins - Home, and Dodge Cummins Diesel Forum as well.
Unless your wiring is completely shot, you won't need to replace it.
These trucks have a few wiring weaknesses. Headlight relays solve the smoking switch, dim light problems in one shot. Heater motor relays help that smoke problem. If you're doing serious towing, like fiver, gooseneck, or double tow, the stock provisions for trailer wiring are woefully inadequate.
Here's my solution to the trailer wiring for a fiver/bass boat double
I want to rip the computer out completely an a all new wiring system for aux lights etc off road use rig an all nothin stock truck wont have ac an dont think im gonna run a radio i just am second guessing my mind on the wiring an the trans mission wiring mainly i have a pot setup from dnr customs an its still a 46rh so non lockup 1-3rd is pressures for shifting sooooo looking for somethin that is from like painless
any input from yalls?
Preheat will run on momentary switch driven by your finger.
OD can be either manual on a toggle or on a pressure switch or both.
New here, but detailed threads on all the above at DTR.
At that point, PCM is useless.
hope it helps
John
Trucks been scabbed together from previous owners (3 others not including me) rear half of the truck is all redone half assed an fuse block is scabbed together to say the least....truck will drain a 960cc 12 volt battery in about 2 hours if it stays hooked up and I got tired of unhooking it everytime I went somewhere....plus I plan to run lots of aux lighting an cooling fans a cb an mainly thats it just to make it a multi use rig
May 8, 2015 11:10 AM
Apr 8, 2015 06:10 PM
Jan 8, 2015 03:00 AM
Mike H
Nov 25, 2014 03:13 PM
