1992 dodge cummins charging system problems
Old Sep 17, 2012 | 06:33 PM
miller215's Avatar
Default 1992 dodge cummins charging system problems
ok ive been working on my charging system alt is good but i am only getting 10 volts out of alt when i un plug altenator wires and the truck acts no diff any help please
Old Sep 17, 2012 | 07:54 PM
bladeyamaha's Avatar
Bad alternator. I'm guessing.
How's the regulator? Need a new one? There is a A C Delco one available one from O'Reilly's Auto for the 1991 Vin C trucks. Its like $50, better one than the house or BWD one IMO.
Last edited by bladeyamaha; Sep 17, 2012 at 07:54 PM. Reason: Automerged Doublepost
Old Sep 18, 2012 | 10:52 AM
j_martin's Avatar
First off, your alternator is regulated by the PCM.
Question, are there any other things going on, like OD not working, tachometer not working?
IF so, then the troubleshooting should go to PCM startup, likely a sensor like the CPS.
If not, then check the fielding on the alternator. If you look at the back of the alternator, there,s a large stud, and 2 small ones. Now, with a test light:
1. Large screw bright (battery). If not, then the fusible link between the alternator and the battery is bad.
2. One of the 2 small studs should be bright, and the other blinking/flashing.
a. Both dark. PCM, or ASD problem, no field voltage available.
b. both bright PCM , or wiring to same. No field input from PCM.
c. one bright, one dark. Alternator is bad. (being fielded, no output)
The quickest and least expensive path to a repair is proper diagnostics.
hope it helps
Old Sep 18, 2012 | 02:49 PM
Here is a link to a rebuilt PCM.
DODGE RAM TRUCK Cummins Diesel Computer ECM ECU PCM | eBay
Or you could bypass the computer and regulate with just the alternator and 12 volt regulator. HERE!
http://www.cumminsforum.com/forum/94...w-89-02-a.html
http://www.dieseltruckresource.com/f...n&onlynewfaq=1
Old Sep 19, 2012 | 06:36 PM
tji4cat's Avatar
make sure you have a good ground and that your voltage regulator isn't shot.
Old Sep 19, 2012 | 08:26 PM
miller215's Avatar
in reply to j martin every thing else works no other problems besides it not charging ive went thourgh every thing but on the fusible links you can unplug them but no fuses cant figure it out
David90
Sep 16, 2015 12:48 PM
Ohiocummins99
Jul 8, 2015 07:30 AM
Linkbeltpower
For Sale
Dec 16, 2014 08:44 AM
kamwil54
Nov 2, 2014 08:48 PM
Oct 10, 2014 08:10 AM
