reverse lights
Old Sep 17, 2012 | 06:15 PM
dieseldude848's Avatar
Default reverse lights
my truck keeps poping the 10amp fuse for reverse. it doesnt pop it right away though, takes about a week. any ideas of where to look?
Old Sep 17, 2012 | 06:16 PM
H.R.D's Avatar
Start at the bulbs, then work your way to the fuse box.
Old Sep 17, 2012 | 06:26 PM
RAW's Avatar
RAW
Between the fuse and reverse lights is a switch in your transmission. When the shift linkage goes into R, it allows power to run back to the light bulbs. Somewhere along the way you have a short.
Old Sep 17, 2012 | 06:34 PM
ive changed the bulbs, and redid the trailer mate harness blocks, they were all corroded. so idt my problem is there, in the day light tommorrow if its not raining ill start to follow the wires off the reverse switch in trans. is it possible that the switch is bad, and which plug is it on the trans?
Old Sep 17, 2012 | 06:37 PM
H.R.D's Avatar
This should help....Post #6
reverse light switch location ? - Dodge Diesel - Diesel Truck Resource Forums
Old Sep 17, 2012 | 06:43 PM
thats for a 5spd, i have a slushbox.
Old Sep 17, 2012 | 06:56 PM
H.R.D's Avatar
It is going to be the neutral safety switch which controls the reverse lights.
How to Replace a Dodge Ram Backup Light Switch | eHow.com
Old Sep 17, 2012 | 07:11 PM
i just looked with the flash light, theres 3 plugs from what i could see the one furthest to the back with 2 wires seems like it would be the reverse one. im going to follow it up tommorrow.
Old Sep 17, 2012 | 07:15 PM
H.R.D's Avatar
Rite on.
Old Sep 17, 2012 | 07:19 PM
ok mint. if everything checks out good, then where should i look? also seeing where the switch is just completing a circuit, i dont see how it could go bad. if it had multiple wires then i would say it could be sending a bad signal. if that makes sense.
