Killer Dowel Pin...
Old Sep 16, 2012 | 11:00 PM
Cree's Avatar
Default Killer Dowel Pin...
Anyone tried the kit from Geno's where you drill and tap the side of the case to hold the KDP in place? I like the look of it better than pulling all sorts of stuff off the front of the engine... As a gunsmith, drilling and tapping is a lot easier for me than wrestling timing covers and gaskets. Any feedback on the kit? I know there are some other potential loose bolts that really need to be addressed when you tab the KDP, so what are diesel shops getting for this job? I really am a little leery about digging this deep into the engine. Yeah, I know, I can gain a valuable experience by doing it myself, but I worry about the part where you get it all back together and it works as good or better than it did, .
Thanks-
Old Sep 16, 2012 | 11:06 PM
H.R.D's Avatar
It is really not a difficult job to do yourself. I have no experience with the Geno's kit but I am sure somebody will. If not contact Geno's Garage yourself and see what they have to say about it.
Old Sep 17, 2012 | 12:03 AM
1stgenblowingsmoke's Avatar
Done 3 of em sofar all 2nd gen motors ones in my 93 though. uh really it'll take me an hour to do honestly it's simple there's a good writeup on the web here somewhere with detailed pics n stuff of how to do it.
Old Sep 17, 2012 | 08:06 PM
Cree's Avatar
Thanks for the ideas, guys. I need to look into it a little more. Talked to the local diesel shop today, when I asked about the KDP, the owner pulled out a busted cover and said, "yeah, it is a problem." He didn't try to sell me on it, but did tell me I need to address it. I guess when the Cummins comes home I need to sort that out. Thanks for the $.02...
Old Sep 17, 2012 | 09:16 PM
Edahall's Avatar
easiest kdp fix - Dodge Diesel - Diesel Truck Resource Forums
http://dodgeram.org/tech/dsl/Dowel_Pin/bolt.htm
Old Sep 17, 2012 | 11:00 PM
tiremann9669's Avatar
I'd just pull the cover and stake the pin.
Old Sep 18, 2012 | 10:04 AM
Agreed by the time your done drilling it n all that other stuff you could have it almost put back together. that kit is only good if the kdp is all the way in still which you can never tell.
Old Sep 18, 2012 | 10:15 AM
Plus wheres all the shavings going as you're drilling and tapping
Also you need to loctite the housing bolts, mine were barely snug
Last edited by tiremann9669; Sep 18, 2012 at 10:15 AM. Reason: Automerged Doublepost
Old Sep 19, 2012 | 06:40 PM
tji4cat's Avatar
it work good to just take a center puch mushrum that pin just alittle bit.
Old Sep 24, 2012 | 10:46 AM
t-bone117yamaha's Avatar
or the old coat hanger trick there was a wright up somewhere where a guy took a metal coat hanger and basicly made a washer with a little tab to cover the hole. ive used that trick to help everybody i know with thiers ever since. nobody has ever had a problem.
Aug 25, 2015 07:10 PM
windage
Jul 17, 2015 12:45 PM
Weeks327
May 11, 2015 10:43 AM
359ci12v
Apr 9, 2015 08:24 AM
dieseldeal
Mar 24, 2015 12:11 AM
