When you hit brakes steering wheel jerks to right
Old Sep 16, 2012 | 12:43 PM
trentonwest29's Avatar
Default When you hit brakes steering wheel jerks to right
I have a 1994 dodge ram 2500 and if you hit brakes hard the steering wheel jerks to right it has new pads,rotors, and calipers on it any ideas?
Old Sep 16, 2012 | 03:18 PM
ricet07's Avatar
Pinched hose on drivers side more than likely. Put new hoses on and bleed the heck out of them again.
Old Sep 16, 2012 | 04:18 PM
tiremann9669's Avatar
Or possibly a bad tie rod causing it to pull when you brake
Also you could try swappin the tires side to side and see if it still pulls right.
Last edited by tiremann9669; Sep 16, 2012 at 04:18 PM. Reason: Automerged Doublepost
Old Sep 17, 2012 | 06:31 AM
98 Cummins's Avatar
If you pry open the clamp that holds the flex line clean it out from rust and dirt, and pinch it back to the line that Might help. Seen that happen before, or you might have to re-adjust your rear brakes. It was happening to me, So I readjusted my drum, and the pull to the left was gone.
Corb
Old Sep 21, 2012 | 10:50 AM
1AMatt's Avatar
Site Sponsor - 1aauto
I was gonna guess a stuck caliper but looks like you replaced them... Did you check the condition of the brake hoses?
Old Sep 21, 2012 | 03:40 PM
No gonna check hoses when it gets out of body shop
Old Sep 24, 2012 | 08:16 PM
captain_stabbin's Avatar
sticking caliper.....
Old Sep 26, 2012 | 11:48 PM
Djc25541's Avatar
Bad caliper, I got a bad one from my local auto store
Old Sep 27, 2012 | 12:06 AM
Ericcon's Avatar
I too have noticed such kind of steering wheel jerks while hitting the brakes strongly, but it is not frequent in my car, happens rarely. BTW, now I'm too going to check out the brake hoses for fixing this problem.
thanks !
Radioking1777
Jun 9, 2015 04:13 AM
scottxmorris
Nov 30, 2014 09:25 PM
GCTownes
Oct 21, 2014 10:17 PM
1MooseheadPlease
Oct 13, 2014 05:33 AM
