Can you??
Old Sep 15, 2012 | 11:24 AM
cheer's Avatar
Default Can you??
Im woundering if i can replace part of this line with a good rubber one does anyone know or is there to much pressure or something??or by pass it or something? Whats it for exactly?
Old Sep 15, 2012 | 11:41 AM
RAW's Avatar
RAW
Factory transmission, or mild build, you will only have about 100psi max in the lines. A weel built will have up to 300psi in certain situations. You could cut the bad piece out, add rubber hose, and use at least 2 hose clamps per end.
Old Sep 15, 2012 | 11:59 AM
biged681985's Avatar
Ideally you would want to splice the line with metal lines
B.E.D.S.
Big Ed's Diesel Service
Old Sep 15, 2012 | 12:02 PM
RAW's Avatar
RAW
Did you find a cracked line, is that why you are thinking of splicing?
Old Sep 15, 2012 | 12:32 PM
H.R.D's Avatar
You can get hydraulic soft line to replace the metal ones. I am sure you can even put those male fittings on it too.
Old Sep 15, 2012 | 12:45 PM
RAW's Avatar
RAW
My entire hose system for my trans cooling is 5/8" hydraulic hose with JIC ends. It is excessive, but it was readily available to me.
Old Sep 15, 2012 | 12:59 PM
Or u can use hydraulic line like stated. But just using rubber line and hose clamps, I'm not a fan of that
B.E.D.S.
Old Sep 15, 2012 | 01:26 PM
RAW's Avatar
RAW
As non-ideal as it is, it is the way the factory cooler is connected to the system.
