Dream Turbo
Old Sep 15, 2012 | 11:05 AM
scottmorgan's Avatar
Default Dream Turbo
i got some gears turning but no pockets burning.
IDC who takes the idea but someone has to do it.
these pictures show (not in scale) two 3 port manafolds for the 5.9 cummins. the manifolds would each run to is own small vgt turbo. the vgts could spool quickly and then open up to alow the exhaust through with no restriction. the exhaust would then y together and run to a larger single waistgated turbo to alow for big boost. a couple importartant things on this would be that the vgts run off the same programer. just pg tail the signal for them this would alow for the engine to have equile load on each cylinder. another one is the vgt turbos boost must enter a difrent port in the inter cooler. or it could be ran with the boost from the little vgts into the air intake of the bigger turbo.
witch one would be better? this is just a rough draft there are some things that would not work out in reall life right now. like the small piping and some the vgt to larger turbo intake pipe.
what do you guys think any ideas on where to acually start this would be great!
Attached Thumbnails Dream Turbo-9-15-2012-10-42-32-am.jpg   Dream Turbo-9-15-2012-11-00-54-am.png
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
n2brk
Feb 21, 2015 09:05 AM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
