raptor or AirDog... 100 or 150... Edge or Quadzilla?
Old Sep 15, 2012 | 04:42 AM
Cook's Avatar
Default raptor or AirDog... 100 or 150... Edge or Quadzilla?
Ok folks... Looking for some opinions. First off the lift pump. I've run the AirDog on three common rail trucks and I ran a Raptor on my old 12v. All the pumps have performed flawlessly. I felt like the extra filters were needed on the common rail trucks since the fuel needs to be blessed by the Pope to avoid injector issues. But I'm not so sold on needing the extra filters on the older style trucks. Are they really worth the extra $$$? Next question 100 or 150? Since I'm currently running a block mounted pump, I could run a 100 off the factory pickup where I would have to run a draw straw for the 150. Would the 100 support a set of 125 injectors & chip on a H.O. truck? And then last but not least.... Looking at doing a bigger chip. I like my EZ but want more. Looking at either a Juice w/ Attitude or an Adrenaline w/ Pulse? I've run the Edge before and liked it but the quad is cheaper and has a larger rated HP increase. Any problems/concerns that I should know about? Any info or opinions are greatly appreciated.
Old Sep 17, 2012 | 11:12 AM
lobsterman04's Avatar
I do believe the 100 will support 125s and a pressure box like the Edge or Quad. Not 100% so don't take my word for it. As for the box...i feel that both boxes are great. You will also have "nay sayers" for both. Do you want settings you can heavily modify or the simplicity 5 levels? The Quad offers unlimited options on tunability where as the Edge has it's factory settings and thats it. As for which has more power...again, you'll hear the same...Egde, no Quad. Quad, no Egde... I like the endless options, so I chose the Quad Adrenaline. but the Edge is also a great box. Good luck in your quest
Old Sep 21, 2012 | 10:12 PM
01quadcab's Avatar
edge and the airdog 100 with filters better filtration is always a good thing
