Borg Warner S366
Old Sep 14, 2012 | 07:41 PM
angelic0-'s Avatar
Default Borg Warner S366
These are the specs for a turbo i'm being offered at 500$..
It's a Borg Warner Performance S366 Turbocharger
Compressor wheel is 66mm extended tip
Turbine wheel is 74mm
Twinscroll T4 Flange, v-band downpipe beveled 4.21" marmon downpipe flange
.91 Turbine a/r
So the question will be, will this spool with 5x.012 and be streetable.... and could be used for towing... ?
Old Sep 14, 2012 | 07:58 PM
biged681985's Avatar
That turbo is laggy as can be even with 5x.018s
B.E.D.S.
Big Ed's Diesel Service
Old Sep 14, 2012 | 08:02 PM
angelic0-'s Avatar
so what specs should i rather be looking at, i think my 16cm2 HX35 has a higher A/R... so shouldn't that be more laggy ?
i was under the impression this was similar to a SuperB ?
Old Sep 14, 2012 | 09:11 PM
turbo2332's Avatar
its not just ar and the cm housing #'s. a bigger wheel is heavier and harder/slower to move. lots and lots of guys run 65mm wheels including myself on pickups that still have to be trucks. i really like my 62/65. great all around turbo. wont set any land speed records but the truck will get up and go. a 65mm wheel with a 14cm housing isnt going to spool like a 74mm wheel and a 14cm housing. 21 totally different creatures.
Old Sep 14, 2012 | 10:20 PM
angelic0-'s Avatar
so i should blow this off ?
Old Sep 14, 2012 | 10:42 PM
turbo2332's Avatar
yes
Flynryan9
Jan 31, 2015 09:36 AM
