No overdrive/lockup and some other things
Old Sep 13, 2012 | 09:42 AM
KodyC's Avatar
Default No overdrive/lockup and some other things
The problem started out as the truck would kick in and out of overdrive and lockup. And the tach would jump all over the place. It still does this some times but now sometimes the tach will stop working completely and some of the other gauges. All the dash lights will come on and the OD light will come on like i turned it off. And then after awhile it will run fine. Also when it starts acting up i really have to give it the throttle for it to start even wanting to take off. If someone has some ideas on what could cause this I wouldnt mind hearing them.
Old Sep 13, 2012 | 12:13 PM
lodal cummins's Avatar
Clean your crank position sensor and re gap that may help
Old Sep 15, 2012 | 04:36 PM
KodyC's Avatar
Cleaned it it seems to be working alright for now. Thanks
