Turbo Question
Old Sep 13, 2012 | 07:00 AM
chadcycle 2500's Avatar
Default Turbo Question
I'm looking to possibly upgrade my turbo? I belive I have a HY-35,not sure which way to go to get a little more power from this.Should I get a programmer or just injectors???? would the HX-35 be enough by itself with no injector change? Any input is appreciated, Thanks
Old Sep 13, 2012 | 07:15 AM
62mm Phat Shat 62
Luke
Old Sep 13, 2012 | 07:44 AM
biged681985's Avatar
What all is done to your truck? I can't see your sig
B.E.D.S.
Big Ed's Diesel Service
Old Sep 13, 2012 | 07:52 AM
RAW's Avatar
RAW
2001 Ram 2500 4WD,4.10'sFass lift pump,ATS Copilot,Glowshift gauges.K&NColdair,Bigger boost elbow, Gearvendor overdrive,(now in!) custom lock up & overdrive control switches, 4in exhaust,all new guides&exhaust valves,plained , ARP head studs, someday programer or RV275 injectors
A HX35 is a mild increase in performance compared to the HY35. It does give you the option of making a HX35/40 hybrid though, which isn't a bad turbo.
Old Sep 13, 2012 | 07:53 AM
Smarty=Cummins's Avatar
I didnt know ats copilt would work on are trucks
Old Sep 13, 2012 | 08:29 AM
Since you don't have injectors or programmer yet, a hx35 or a hx40 would be as big as I'd go.
62 would be a lil laggy with just stock fueling. Add a set of 100-125hp injectors to a 62 would be a good starting set up
B.E.D.S.
Old Sep 13, 2012 | 12:02 PM
scottmorgan's Avatar
i went with th 351 vgt turbo it cost me about 900 dollars before selling old parts and when my truck is on stock its a great spool and it pumps about 35 psi on stock. when i tuen up he programer and lett it go i get super spool up and i can build 60 psi. the turbo will not only cover you now with little mods but it will be good for heavyer injectors and a programer in the future.
if you want to just o to hx35 i have one for sale in the for sale section for $150 it was a great turbo i just put the vgt on in its place. here is my add --> https://www.dieselbombers.com/sale/102096-hx-35-a.html
Old Sep 13, 2012 | 11:37 PM
blacksally's Avatar
i need to upgrade my turbo to my 150hp injectors put to much fuel n it gets hot fast!
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
torg73
May 11, 2015 03:08 AM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
