NV4500 swap from a 727
Old Sep 13, 2012 | 04:21 PM
Cow tipper's Avatar
Default NV4500 swap from a 727
My 727 3 speed auto transmission just went out. I was wondering what all I need for a nv4500 swap?
Or would it be easier to put a getrag 5 speed in it?
Last edited by Cow tipper; Sep 13, 2012 at 04:21 PM. Reason: Automerged Doublepost
Old Sep 13, 2012 | 09:17 PM
cummin_un_glued's Avatar
FormerVendor
the only thing different between doing the swap to a getrag or a nv4500 is you would need a different engine backing plate for the nv4500, but imo it would be well worth it. the rest of the swap parts would be the same.
Old Sep 14, 2012 | 12:00 AM
biged681985's Avatar
Are you looking for a 4wd or 2wd nv4500? I have everything for a 2wd swap if that's what your wanting to do
B.E.D.S.
Big Ed's Diesel Service
Old Sep 14, 2012 | 06:57 PM
Cow tipper's Avatar
Found out that converting the manual would take a lot of time. Anybody know if a 47rh would bolt right up to the engine? I can get the t case also. Would this increase the performance by any? What would you guys do the 727 3 speed or the 47rh 4 speed?
Old Sep 14, 2012 | 07:17 PM
FormerVendor
yes the 47th would be better because it is a lockup trans where your 727 isnt but again you would have to change the engine backing plate but thats not a big deal. also you would have to shift the OD with a toggle switch as well as the lockup for the TC.
Old Sep 14, 2012 | 07:27 PM
Cow tipper's Avatar
Yupp well I don't know how to do any of that haha so thanks but a new 727 is goin in.
Old Sep 14, 2012 | 08:24 PM
12 valve and proud's Avatar
727 is a great transmission if you take care of it man!
As long as you adjust the rear band properly every 100,000 miles you'll be set! That's why they had the 727 on Hemi's back in the 60's? (somewhere in that era)
Stick to the auto, they last longer and less headaches!
Old Sep 14, 2012 | 09:20 PM
FormerVendor
its not hard at all. we have to do the same thing in our drag truck because of the manual valvebody.
Jonrarick
Oct 25, 2016 01:32 PM
ReckONE
Diesel Engine Conversions
Feb 25, 2015 09:41 AM
DuramaxBen
Feb 6, 2015 10:32 AM
CumminsMan2.0
Dec 11, 2014 04:57 AM
Jgloveracob
Nov 16, 2014 07:27 AM
