Amsoil BMK 11
Old Mar 6, 2008 | 05:14 PM
Redpatcher0481's Avatar
Default Amsoil BMK 11
I just bought a BMK 11 anything special I need to know about installing it?
Old Mar 6, 2008 | 05:53 PM
jstange2's Avatar
Pretty simple. I just took the center plug out of the top of the full flow filter mount and tapped for my supply. I mounted my bypass on the body mount in front of the front passenger tire.
1 is where it comes out of the filter mount
2 is where it goes down to the bypass
Bypass location
Hope it helps
Josh
Did you get the billet aluminum oil return cap?
Josh
File Type: jpg
File Type: jpg
File Type: jpg
Old Mar 6, 2008 | 07:35 PM
Looks pretty easy thanks for the pics.
Yes I got the billet return cap.
Old Mar 6, 2008 | 07:39 PM
jstange2's Avatar
When we put mine in, we took the wheel and inner fender off. If you go that route.
Josh
Old Mar 6, 2008 | 07:53 PM
Thanks, that looks like a good spot.
Old Mar 6, 2008 | 07:54 PM
jstange2's Avatar
The only reason I wouldn't have put it there is if I were an avid off roader, but I'm not.
Josh
Old Mar 6, 2008 | 09:27 PM
Heath's Avatar
Authorized Amsoil Dealer
Looks pretty good. Only other thing is if you wanted to eliminate the loop coming out of the oil sending unit, you could use a 90 degree fitting and the hose could be more direct downward...but nothing wrong with this. The loop is nice and round as to not restrict or cause stress.
Old Mar 7, 2008 | 09:17 AM
jstange2's Avatar
I would have used a 90 but I had been planning to mount it in front of the intake horn (whatever it's called). I probably should switch it out though. I had to get a 45* elbow for the (I think) return line out of the bypass.
Josh
wlofton
11
Jun 26, 2018 08:58 AM
Spk329
May 23, 2015 12:46 PM
