Long cranks before starting
Old Sep 12, 2012 | 04:46 PM
Strokinandsmokin's Avatar
Default Long cranks before starting
Hey guys I've got an 06 f-350 all stock except afe stage 3 intake and mbrp turbo back exhaust. Every time I go to start I wait for the light to go out and crank her over it takes between 5-10 secs to start the truck. I change my oil and fuel filters every 5-8 thousand miles. I'm new to powerstrokes so does anybody know what it could be? Or point me in the right direction. Trucks got 141k on the clock
Old Sep 13, 2012 | 01:22 AM
ntmdtr3fan's Avatar
Have you checked your batteries and tested your FICM? Have the batteries load tested. If one is bad replace both as the other will fail shortly after the first. The FICM test procedure is a sticky above in the 6.0 section. 4 to 7 seconds is my average on my truck. Longer when its colder and faster when its warmed up.
Old Sep 13, 2012 | 07:39 AM
Mdub707's Avatar
Exactly what he said. Except 4-7 seconds sounds like a VERY long time to me too. Mine fires in less than 2 seconds when I start cranking, no matter how warm or cold it is.
Old Sep 13, 2012 | 09:19 AM
Mine used to start in about 2-3 seconds no matter what the temperature was but something has changed. It still runs fine but I've lost fuel MPG's too but I just put a leveling kit and 35's on the truck so I figured the bigger tires was prob most of my fuel issue.
Old Sep 13, 2012 | 12:34 PM
Mdub707's Avatar
Well like was already mentioned, you should take your batteries out and have them load tested, and then test your FICM.
Old Sep 13, 2012 | 01:45 PM
Will do. I read the sticky a little it looks pretty straight forward.
GasItOut
35
Jul 22, 2015 01:11 PM
hurriedcoyte
Jun 19, 2015 06:26 AM
dandbmcc
Mar 14, 2015 11:05 PM
cutthroatxxx
Dec 14, 2014 08:15 PM
weatherby
99-03 7.3L Performance
Nov 5, 2014 10:45 PM
