ABS Light and Brake Light
Old Sep 12, 2012 | 01:48 PM
CR9712v's Avatar
Default ABS Light and Brake Light
My abs and brake light are both on and stay on.
could it be one of the sensors is bad or the sensor on the rear differential needs replaced? .... i cant have the brakes going out ...
Old Sep 12, 2012 | 03:38 PM
gyayo2012's Avatar
I had the same problem from what I've read the sensor is the most comon culpret.. but my isue was the tail light harness was wedged under my rotted bed and was grounding out so i kept poping the brake fuse.. so my sug. is check your fuse and wires then the sensor.. maybe just a cleaning will do.. hope this helps
Old Sep 12, 2012 | 06:27 PM
CR9712v's Avatar
ok will do. thanks.
Old Sep 13, 2012 | 12:43 PM
1AMatt's Avatar
Site Sponsor - 1aauto
Sensor in the rear diff
Old Sep 13, 2012 | 06:51 PM
CR9712v's Avatar
checked fuses and wires. good. cleaned sensor. a whole 2 minutes.
disconnected battery for 15minutes. rolled the bad boy over and no more lights.
thanks is was erkin me.
Old Sep 13, 2012 | 07:08 PM
mysterync's Avatar
Vacuum leaks often cause the vacuum switch to illuminate the brake light.
Sent from my DROID BIONIC using Tapatalk 2
Old Sep 13, 2012 | 08:29 PM
CR9712v's Avatar
my dash was lit up like a christmas tree... the odometer and none of the gauges worked correctly. blown alternator or something stupid like that... it was fixed, so then my brake and abs lights came on so it got me frustrated and i found out after further knee scraping on my driveway that these lights were due to my sensor being covered in an inch of mud XD. simple clean and fix. i check/service over my hoses and entire truck regularly. Its the only thing to my name. I pay enough for it.
asajay
10
Sep 8, 2015 10:40 PM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
Altonlee
Ford Powerstroke 2011-Up 6.7L
Mar 9, 2015 09:27 AM
FELTONMICHAEL
Dec 28, 2014 01:09 PM
yams
Nov 29, 2014 09:25 PM
