when starting engine occationally goes to full throttle.
Old Sep 12, 2012 | 12:02 PM
willyslick's Avatar
Default when starting engine occationally goes to full throttle.
installed new turbo,stage 2 injectors(75 horse)3200 govener spring.
have re indexed the throttle lever but not quite sure if on the right mark.
have tps disconnected now and runs fine while sitting at all engine speeds but havent tried ful throttle.
herd about useing a pot instead of tps
checked tps seems smooth and have adjusted too 1 volt at idle.cleaned connector
could it be tps or index still off ?
what would make it go to full throttle at engine start by itself? power screw maybe ......help
Old Sep 13, 2012 | 12:22 AM
Olgrey93's Avatar
Check your high idle screw locknut. Maybe it worked loose and the screw found its way up there
Old Sep 13, 2012 | 12:36 AM
BC847's Avatar
Yes.
Have you turned yours in? If so, back it out about a quarter-turn ~ half-turn.
burndiesel
10
Feb 7, 2023 01:15 AM
krinderhagen
Dec 31, 2014 07:12 PM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
Joel Steven
Nov 16, 2014 05:49 PM
1stgenswap
Nov 3, 2014 09:45 PM
