lift pump recommendations
Old Sep 12, 2012 | 08:27 AM
chuffysplace's Avatar
Default lift pump recommendations
Newbie here. Finally going to start a buildup of a bone stock 02, auto with 80K gentle miles. It will be used as an backup daily driver and snowmobile and boat trailer tow vehicle. Here is my future plan (as of now): lift pump and EJWA (with display for gauges so I check pump pressure), later on add exhaust, intake, tap the pump and then a trans build up. Possibly injectors and turbo; we’ll see.
However…first things’ first - lift pump. Pardon my newbie-ness…..but stock one looks to be on the driver side of the engine block, right by the injector pump correct? So it’s a remove and replace, correct? Looks fairly easy, but I could be wrong. Do I need any special tools? More importantly, any recommendations on one? I’m looking at things like ease of installation, quality, and also the price of that brand’s replacement fuel filters as I’ll need them down the road.
Thanks all.
Old Sep 12, 2012 | 10:10 AM
GuyWithA24Valve's Avatar
Yep, it's right behind the fuel filter bowl on the drivers side of the engine. Installation of an aftermarket lift pump is pretty straight forward. I have a Fass 150HD in mine and I'm happy with it
Old Sep 12, 2012 | 11:55 PM
blacksally's Avatar
install is a breeze i use to install the older fass systems years ago when i was a noob at a shop i worked at in HS, im gunna get a 150gph asap! good luck on the build up man
Old Sep 13, 2012 | 01:36 PM
helph's Avatar
Airdog 2
Old Sep 16, 2012 | 08:20 PM
Thanks all
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
