Super b? Or which single
Old Sep 10, 2012 | 08:59 PM
Shwill's Avatar
Default Super b? Or which single
New to this forum well read a lot but first post. Trying to decide which turbo I want. I have a 97 p pumped 4bt. I know it's not a 12 valve but they are very similar. Right now the bosch dealer is cutting the valves, 4kgsk , and bench flowing. I have 5x12's. And stock head bolts for now. My parts dealer is trying to talk me into going with a super b turbo. Which would probobly be awesome if I could get it spooled up. Not sure if my 4 cylinders will spin a 14cm exhaust housing up or if it will be way to laggy. Any ideas would be appreciated. Thanks
Old Sep 10, 2012 | 11:09 PM
SCHMITTY's Avatar
What vehicle is this in? I ran a fork lift with a 4bt.
Old Sep 11, 2012 | 12:04 AM
Shwill's Avatar
Going in a standard cab 97 powerstroke. Was going to do a half ton but I got a good deal on it and it's got heavy duty enough trans and axles allready in place. I really just need to know if this thing will get a super b to light. Or do I need something smaller?
Old Sep 11, 2012 | 12:30 AM
angelic0-'s Avatar
i think you will definately need to go smaller, unless you get more fuel... and then it will be VERY hot !
Old Sep 11, 2012 | 12:42 AM
turbo2332's Avatar
i ran a super B for quite some time on a relativly stock 6bt and it was noticably slower to spool over the stocker. i would definatly look into other options for your little 4bt. dont 4bt's come with hx30's or something? do you know the specs of the original turbo so we can get you a little closer guess. its not the housing size that is going to kill you, its the wheel sizes that will throw the monkey wrench.
Old Sep 11, 2012 | 10:32 AM
Shwill's Avatar
no i dont it came on a pallet with an old H1c with a 16cm exhaust housing. i know i wont use that. id like to find something similar to super b but scaled down for my 4b. any suggestions. maybe an hx35? not sure. the bosch dealer aacts like ill have way to much fuel for needs. but reading similar mods to most of your 6b's doesnt seem like you guys are having trouble cleaning up your smoke
Old Sep 11, 2012 | 11:00 AM
turbostang7's Avatar
4bt had an hx30 on them, its a pretty small turbo. An hx35 would be a decent upgrade, or even an he351
Sent from my DROIDX using Tapatalk 2
Old Sep 11, 2012 | 10:42 PM
SCHMITTY's Avatar
What about a used wh1c ? Little shaft play, drilled divider 3/4". I'll sell it pretty cheap. Similar specs to an hx35. 56/58/12 I think. If it only made more usable boost for what I want. It's In good shape I'm just getting ready to upgrade to something a little bigger now that I have more fuel.
Old Sep 11, 2012 | 11:28 PM
RanchhandTCR's Avatar
I would go smaller a 4BT is stock with 90HP your gonna want a quick responce for the turbo with that engine...
Old Sep 12, 2012 | 01:26 PM
Shwill's Avatar
So a super b is an s300 by Borg Warner right? They also make an s200 right maybe more appropriately sized nice single for my application?
