Water in front end
Old Sep 10, 2012 | 12:29 PM
GuyWithA24Valve's Avatar
Default Water in front end
Anybody else have this problem with their front axle? I changed the front differential oil 9 months ago because it was milky. I just checked it this weekend and it was really milky just like before. It's not the cover seal and the pinion seal is fine
Old Sep 10, 2012 | 12:34 PM
dieseldude848's Avatar
do you wheel/offroad the truck? are there any signs of gear oil leaking out?, and check the vent tube to see if the cap is still on it.
Old Sep 10, 2012 | 12:38 PM
Nope, just snow in the winter up here. Otherwise it's all on road/ dry dirt. No mud or water fording. The cap is still on the breather. The pinion seal is not leaking, and the cover isn't either. I'm guessing theres axle seals way up the tubes by the housing?
Old Sep 10, 2012 | 12:40 PM
biged681985's Avatar
I bet you drive through a creek on occasion. It's coming in from one of three places. The axle seals, the pinion seal, or the vent tube
B.E.D.S.
Big Ed's Diesel Service
Old Sep 10, 2012 | 12:45 PM
I don't drive through any water. Honest to God. Just snow in the winter. Which the deepest it's been through is up to the front bumper. But that was 2 years ago. We barely got 3 inches at one time this past winter
Old Sep 10, 2012 | 02:07 PM
maybe some how its condensating in there? when you say milky, is it foaming up too? and what brand gear oil are you running?
Old Sep 10, 2012 | 02:45 PM
Something's going on. It's Lucas gear oil. It's not foaming but there are some bubbles building up
Old Sep 10, 2012 | 06:24 PM
tiremann9669's Avatar
B.E.D.S.
Or possigly the gasket around the CAD
Old Sep 10, 2012 | 11:20 PM
blacksally's Avatar
the cad is that the 4wd unit on axle i resealed mine very easy the axle seals are way up in the axles and are a pain but not to bad.
Old Sep 11, 2012 | 02:19 AM
I'll have to check that out. I can't really tell if the axle seals are leaking, but I'll take a closer look at those too
