getrag input shaft upgrade question
Old Sep 10, 2012 | 01:04 AM
1stGen1990's Avatar
Default getrag input shaft upgrade question
so i just got my dual disc south bend and bigger input shaft in the mail, my question is has anyone here replaced the input shaft before? ive never really torn into a trannsmisson before so im a little worried about this and wondering if maybe i should just pull the tranny and take it to a shop to be done. thanks guys
Old Sep 12, 2012 | 09:36 AM
hiboy_76's Avatar
Where did you get a upgeaded input for a Getrag???
Old Sep 15, 2012 | 10:39 PM
big bad diesel 416's Avatar
Site Sponsor
ya i would like to know too cuz only guy has made one that i know of and he did not sell one
Old Sep 16, 2012 | 12:24 AM
bladeyamaha's Avatar
Could someone shoot me a PM with a estimated cost of over hauling a getrag tranny with all the upgraded parts and every thing I need as far as seals go for a future over haul?
input shaft, after market- Dodge Getrag 360 - Transmission Parts - Products - CHA Gear
Products > Transmission Parts > Dodge Getrag 360
Last edited by bladeyamaha; Sep 16, 2012 at 12:24 AM. Reason: Automerged Doublepost
Old Sep 16, 2012 | 10:02 AM
Site Sponsor
stock shafts
Old Sep 16, 2012 | 12:58 PM
They say they are after market.
I dunno yet.
Last edited by bladeyamaha; Sep 16, 2012 at 12:58 PM. Reason: Automerged Doublepost
Old Sep 24, 2012 | 05:45 PM
getragfixer's Avatar
ok if you ar not a very good tech do not it can be tricky and need shop related tools.now after assembly dont use gear oil use synthetic motor oil recomended is 5w30 how to "fix the problem"the oil level is wrong anyone who has rebuit a g360 can tell you the oil fill plug is located a the bottom of the problem bearing go figure i make a tubethat extedes the fill hole up using 1/4 fittings very good results with this setup.raise the level from 7.5 pint to 7.5 quarts now trans fixed
Old Sep 26, 2012 | 01:17 AM
There is one on ebay.
Old Sep 28, 2012 | 09:50 PM
mossyoak66's Avatar
"Getragfixer" what kind of fittings are you using exactly? I'm needing to over fill mine and have been trying to figure out how to do it without wasting a lot of oil.
Old Sep 28, 2012 | 10:39 PM
Site Sponsor
you can fill it for the top PTO cover bolt with 5 qts of syn 5w-40
as far as shafts go there are aftermarket shafts in stock form
but no one makes an "upgraded" shaft only stock forms
its not like the NV 4500 shafts where you can get a bigger size or one made of stronger material
if your rebuilding nothing special needed besides a press, calipers and snap ring pliers
read this https://www.dieselbombers.com/1st-ge...tml#post942884
and if you have problems pm me and i can walk you through it there not hard at all just pay attention
Last edited by big bad diesel 416; Sep 28, 2012 at 10:39 PM. Reason: Automerged Doublepost
CJJD4640
9
Feb 9, 2015 07:22 AM
