looking for connectors
Any one know where to get electrial connectors for 2004 ford f350 with 6.0diesel. Am looking for the crankshaft position sensor connector and the variable geometric turbo actuator connector.
Thanks
Thanks
Do you actually need to replace these parts? They're not common failure points. Even if I had codes for those I'd be VERY skeptical that they'd need replacing. Or are the connectors broke? I'm assuming that's the case since you only need the connectors...
Here's the turbo VGT solenoid pig tail P/N: 6E7Z-12A690-DA
Not sure on the crankshaft one...
