another question
Old Sep 8, 2012 | 03:35 PM
flipskid's Avatar
Default another question
what are standpipes and dummy plugs? what do they do? Its not tuesday, im just new to this diesel thing. thanks guys! J
Old Sep 8, 2012 | 04:06 PM
biged681985's Avatar
The stand pipe connects the high pressure oil rail to the branch tubes. Branch tubes come from high pressure oil pump. The high pressure oil rails can be swapped from one side to the other. To do that, they use a dummy plug tht is removable.
Posted because I'm bored.
Old Sep 8, 2012 | 04:52 PM
flipskid's Avatar
Default thanks
thanks. is there a reason to change sides? Should upgrades be done if you get to the point of having to remove them?
Old Sep 8, 2012 | 05:52 PM
bobfbigman's Avatar
You hav to remove the oil rail to get to the injectors, once removed the standpipes should be replaced because the seals on them can fail and the new ones have a teflon backer for the orings so they are alot less likely to fail, same with the dummy plugs, they are upgraded as well with the teflon backer because the orings on them can fail and cause a Hot no start condition.
Forks diesel nut
Diesel Engine Conversions
Jul 27, 2015 12:19 PM
torg73
May 11, 2015 03:08 AM
99&91cummins
Mar 4, 2015 01:56 PM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
