tork tek adjustible ofv
Old Sep 7, 2012 | 10:30 AM
gyayo2012's Avatar
Default tork tek adjustible ofv
Is any one running this tork tek adjustible over flow valve?? I'd like to replace mine just for some piece of mind.. But don't know weather to do this adjustible one, a fixed one, or just a stocky,... any input would be great!...
TORK TEK CUMMINS ADJUSTABLE OVERFLOW VALVE OFV020 - Tork Teknology
Thanks in advance!!
Old Sep 7, 2012 | 10:39 AM
RAW's Avatar
RAW
I'd go adjustable. Any modifications to your lift pump system in the future can be fine tuned to keep pressure at the pump inlet correct. I'd like to get one for my VP44.
Old Sep 7, 2012 | 01:09 PM
turbo2332's Avatar
great guys! give them a call and tell them your story, they will hook you up. i run a .060 valve. works great.
Old Sep 8, 2012 | 03:19 PM
gyayo2012's Avatar
yeah im deff. going to order one from tork tek. just have to call them up see which one they would recomend for me.. not sure what the max psi you can get out of the adj one is.. so i was also thinking of an air dogg.. or fass... was thinking of the .040 .050 .060.. because you can't use the .010 .020 .030 with the elect system.. just dont know if i can run a .040 .050 or .060 with the stock pump?!..
