burned out glow plug
Old Sep 6, 2012 | 08:34 PM
7.3 idi 1990's Avatar
Default burned out glow plug
Hi all, I have my 1990 f350, I was forced to put champion glow plugs in it two years ago, and and it wasnt starting right, so i tested the glow plugs and 1 was bad, no ohms and no lite on the test lite, I suspect the contoller caused it to go bad. One question though, Is the the controller supossed to turn off after engine is warm? Why do they not turn off when it's warmed up???
Old Sep 16, 2012 | 08:19 PM
CARP's Avatar
Yes the controller is, you may have a bad controller. Accurate Diesel sells the best controllers for the truck.
Old Sep 17, 2012 | 08:44 PM
dukes-78's Avatar
When you turn the key on the glow plug controller will come and cycle the plugs on for 10sec. Then it will cycle on and off for 10 sec. The on off cycle helps keep from burning out the glow plugs while keeping the cylinders warm. If you have one glow plug bad then the time the controller will stays on will shorten by a small amount, then if another glow plug goes bad then the time will shorten again.
Old Sep 19, 2012 | 04:25 PM
thanks guys
Old Dec 22, 2012 | 12:10 PM
docweld's Avatar
I have a 2000 7.3 with only 78,xxx miles. all my glow plugs are reading 0.1-0.3 ohms. does this mean they are weak and I should replace them?
I just picked 8 brand new ZD-11 and they all ohm the same as my old ones 0.3 ohms. I tested a new set of autolites and they tested at 0.9-1.4 ohms. every thing I have read said 0.8-1.8 ohms are good.
any help would be good here.
Metz1234
Mar 3, 2016 10:20 PM
casper83
Jul 1, 2015 07:55 PM
Texasthb
Mar 4, 2015 08:20 AM
ajwright64
Feb 4, 2015 09:36 PM
norcal6.5
Dec 7, 2014 07:04 PM
